GetElement() returning null on selected ElementId within Family Document
I'm having an issue, where I select an element, retrieve its ID, however when I try doc.GetElement() it returns null. I'm wondering if it is because I am running this in a family document (something I am not used to)
Document doc = this.Document;
if( !doc.IsFamilyDocument )
     TaskDialog.Show("Fam Doc", "Must be run in a family document");
FamilyManager mgr = doc.FamilyManager;
Selection selection = this.Application.ActiveUIDocument.Selection;
ICollection<ElementId> selectedIds = selection.GetElementIds();
ElementId id = selectedIds.First();
// is null
Element test = doc.GetElement(id);
// fails because test is null
ParameterSet pSet = test.Parameters;
Attached is the family file I am using, I selected element 3008 (the upper middle extrusion on the Ref. Level floor plan), however any element selection should yield the same failure.
Thanks!
jeremytammik
In the code snippet you show above, there is no guarantee that
is the same as
I suggest that you eliminate the latter and use one single `doc` variable to address both.
You are using the former document and an element id from the latter.
This will certainly fail if the two differ.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Jeremy's answer is correct I believe, just wanted to add what fixed it for me was in macro manager creating for "application" rather than the specific project. Good luck!
