GetDockablePane throws exception when no document open
harrymattison
harrymattison
During startup I create the pane:
            DockablePaneProviderData data = new DockablePaneProviderData();
            Utils.mainPage = new MainPage();
            data.FrameworkElement = Utils.mainPage;
            Utils.paneId = new DockablePaneId(new Guid(Utils.dockablePaneId));
            application.RegisterDockablePane(Utils.paneId, " ", Utils.mainPage as IDockablePaneProvider);
GetDockablePane works fine when there is a document open. But when no document is open this line throws an exception "The requested dockable pane has not been created yet.\r\nParameter name: id"
 DockablePane pane = application.GetDockablePane(Utils.paneId);
Is there any way to get the dockable pane to work with no document open? Is this a known limitation?
ol.nistratov
I had the same issue and the only one information I found is comment in the Revit SDK samples. So there is no way to get the dockable pane without an opened document.
