Get worksets from detached model
Kisli89
Kisli89
Hello, I need to get all the Workset in the model. I usually use something like this -
List<WorksetPreview> Worksets = WorksharingUtils.GetUserWorksetInfo( ).ToList();
But if the central model is not (removed), then it does not work and you have to use this code -
var wsrevs=new List<WorksetPreview>();
var tb = doc.GetWorksetTable();
try {
   for (int i = 0; i < 999999; i++) {
      Workset wset = tb.GetWorkset(new WorksetId(i));
      wsrevs.Add(wset);
catch {
It seems to me not very right, maybe there is another way?
RPTHOMAS108
 Dim WF As New WorksetKindFilter(WorksetKind.UserWorkset)
 Dim FWC As New FilteredWorksetCollector(Document)
 FWC.WherePasses(WF).ToWorksets()
 'or
 FWC.WherePasses(WF).ToWorksetIds()
Perhaps these objects above?
Note that when you detach a model there is an option for discarding worksets. A detached model only really exists between the time you detach and when you first save it.
Kisli89
Thanks!
 'or
