Get the curves constructing a conduit fitting path
Mustafa.Salaheldin
Mustafa.Salaheldin
Hello
I'm trying to get the path of the conduit fitting by reading the center line geometry.
There is a way to do this in LookUp.
I followed the same logic:
foreach (FamilyInstance fitting in fittings)
    GeometryElement geomElem = fitting.get_Geometry(options);
    LocationPoint? lp = fitting.Location as LocationPoint;
    IList<ElementId> centerlineIds = fitting.GetDependentElements(new ElementCategoryFilter(BuiltInCategory.OST_ConduitFittingCenterLine));
    StringBuilder sb = new StringBuilder();
    foreach (ElementId centerlineId in centerlineIds) {
        sb.AppendLine(centerlineId.ToString());
        Element? curve = doc.GetElement(centerlineId);
        if (null != curve)
            IEnumerable<GeometryObject> curves = curve.get_Geometry(new Options { IncludeNonVisibleObjects = true, ComputeReferences = true });
            foreach (GeometryObject obj in curves)
                    TaskDialog.Show("Revit", "curve found");
First, I access all the instances of the Conduit Fittings in the model through element collector, then get their geometries. Using GetDependentElements I can reach the conduit fittings centerlines, which were supposed when I read their geometries (as done in LookUp) is to get the IEnumerable of the composing Arcs and Lines.
In line 20 of my code, I tried to cast to GeometryElement/GeometryObject/IEnumerable<GeometryObject> but they all return no objects.
Any ideas?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Mohamed_Arshad
Hi @Mustafa.Salaheldin
    I'm feeling proud to reply your query, Since you're one of the prime contributors in Autodesk Forums. You have written everything correct I have made small correct by adding View to options on extracting curves. Kindly check the below code snippet for additional reference.
Reference Code
IEnumerable<GeometryObject> curves = curve.get_Geometry(new Options { IncludeNonVisibleObjects = true, ComputeReferences = true, View=doc.ActiveView });
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Mustafa.Salaheldin
@Mohamed_Arshad Thanks mate, and I appreciate your nice words. Adding the view did the trick. Sometimes you need to refresh your memory and sometimes you are busy with other stuff. 😅
But thanks anyway.
¯\_(ツ)_/¯
Mustafa Salaheldin
Mohamed_Arshad
Thank you for your kind words 🙂
Mohamed Arshad K
