Get SystemType value from a MEPSystem
wils02
wils02
Below is a snippet from my code trying to just get the SystemType from a MEPSystem...
I took some code from Jeremy's post on Traversing the MEPSystems, but for the life of me cannot figure out how to return the SystemType of the system I am looping through. I can print the name, but I specifically need the SystemType. I want to see HydronicSupply or HydronicReturn or SupplyAir...etc.
Will someone please educate me on how to get this? if I have my elementfilter for MEPsystems, why can I not just loop through and say system.type.toString(); or something like this?
FilteredElementCollector systemCollector = new FilteredElementCollector(doc).OfClass(typeof(MEPSystem));
            IEnumerable<MEPSystem> desirableSystems
                = systemCollector.Cast<MEPSystem>().Where<MEPSystem>
                (s => IsDesirableSystemPredicate(s));
            foreach (MEPSystem system in desirableSystems) {
                string cntdSys = system.*** WHAT DO I DO HERE? ***
                sb.Append("System Type: " + cntdSys + "\n");
MarryTookMyCoffe
MepSystem is base class for all systems
try this simple macro
		public void MepSystem()
			Document doc = this.Application.ActiveUIDocument.Document;
                = systemCollector.Cast<MEPSystem>();
			        	if(system.GetType() == typeof(Autodesk.Revit.DB.Plumbing.PipingSystem))
			        		  Autodesk.Revit.DB.Plumbing.PipeSystemType type =  (system as Autodesk.Revit.DB.Plumbing.PipingSystem).SystemType;
                string name = system.Name;
read about
do not worry it only gonna take Autodesk 5 years to fix bug
try this code
 FilteredElementCollector collector = new FilteredElementCollector(doc).OfClass(typeof(MEPSystem)).WhereElementIsNotElementType();
                    IList<ElementId> eids = collector.ToElementIds() as IList<ElementId>;
                    foreach(ElementId eid in eids)
                        Element e = doc.GetElement(eid) as Element;
                        MEPSystem mepsys = e as MEPSystem;
                        ParameterSet ps = mepsys.Parameters as ParameterSet;
                        foreach(Parameter p in ps)
                           if(p.Definition.Name=="Type" && p.AsValueString()!="")
                                s = s + p.AsValueString()+"\n";
                    TaskDialog.Show("name",s);
wils02
MTMC,
Thanks, this got me pointed in the right direction. I didn't realize I could do this sort of thing:
PipeSystemType type =  (system as PipingSystem).SystemType;
I think I have some working code now that I will publish on the forums soon!
wils
