Get subcomponents from familyinstance
oyvind.knappskog.olsen
Hi
How can I get the subcomponents from the 3 familyinstances in the file attached?
I have tried the GetSubcomponents method but it returns 0.
Regards
Øyvind Knappskog Olsen
Norconsult Informasjonssystemer AS
JimJia
Dear Øyvind Knappskog Olsen,
Per our investigation, these three elements are AssemblyInstance but not FamilyInstance, so you can use AssemblyInstance.GetMemeberIds() to retrieve the sub components.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Mustafa.Salaheldin
Thanks to @JimJia. I've prepared a sample code to do the job:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
using System.Diagnostics;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            FilteredElementCollector collectorAssemblyInstance = new FilteredElementCollector(CachedDoc);
            collectorAssemblyInstance.OfClass(typeof(AssemblyInstance));
            List<AssemblyInstance> AssemblyInstances = collectorAssemblyInstance.Cast<AssemblyInstance>().ToList();
            StringBuilder sb = new StringBuilder();
            foreach (AssemblyInstance ai in AssemblyInstances)
                sb.AppendLine(string.Format("Assembly {0} contains:", ai.Name));
                sb.AppendLine(string.Format("======================"));
                List<ElementId> members = ai.GetMemberIds().ToList();
                foreach(ElementId id in members)
                    sb.AppendLine(string.Format("\tElement with Id: {0}", id.ToString()));
            TaskDialog.Show("Revit", sb.ToString());
            return Result.Succeeded;
        #endregion
If this code satisfies your need pleas mark this reply as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
JimJia
Did you get chance to verify this case? do you think we can close this now?
Jim Jia
