Get Section's cropbox
ttnhan1
ttnhan1
Hello, I am working on the section, which makes me slightly confused.
I need to create the dimension outside of the crop region. So, I get the currently active view's crop box by this code:
doc.ActiveView.CropBox
These are the Max/Min points that I got from the above crop box:
However, when I click "show crop region" on Revit, the crop region on Revit has different Max/Min points.
I know that the crop region is the ActiveView.CropBox.  It still works fine with FloorPlan, but with Section, they are different.
Did I understand wrong somewhere?
How can I get the crop region (crop box) with the Min/Max points I got in Revit Lookup?
jeremy_tammik
Please search this forum for existing answers, e.g., using the search term "cropbox":
https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&...
ttnhan1
https://forums.autodesk.com/t5/revit-api-forum/how-to-retrieve-the-cropbox-s-coordinates-of-a-sectio...
I followed this topic to get the section's cropbox. Thanks for your help
