Get referring view using API
anvdi
anvdi
I am having some trouble when using API to find the referring view for the selected view
Does anyone have any ideas for this issue?
dfoth
View Reference isn't available in the API, yet. I don't know why. I need it as well.
Sean_Page
This is possible, you have to use the Viewers category to collect them.
#Sean Page, 2024
import clr
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import *
clr.AddReference('System')
from System.Collections.Generic import List
clr.AddReference('RevitNodes')
import Revit
clr.ImportExtensions(Revit.Elements)
clr.AddReference('RevitServices')
import RevitServices
from RevitServices.Persistence import DocumentManager
doc = DocumentManager.Instance.CurrentDBDocument
#Select a View (This test is an Exterior Elevation
check = UnwrapElement(IN[0])
res = []
#Collect All Views
allViews = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views).WhereElementIsNotElementType()
for view in allViews:
    #Check to make sure it isn't a View Template
    if not view.IsTemplate:
        #Collect Viewers that are within the Views Collector
        viewers = FilteredElementCollector(doc, view.Id).OfCategory(BuiltInCategory.OST_Viewers).WhereElementIsNotElementType()
        for viewer in viewers:
            #Check the View and Viewer name to find the matching ones
            if viewer.Name == check.Name and viewer.Name != view.Name:
                res.append(f'{view.Name} - {view.get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER).AsString()}/{view.get_Parameter(BuiltInParameter.VIEWPORT_SHEET_NUMBER).AsString()}')
OUT = res
List of Views the Elevation Shows up in and the Detail / Sheet of those Views if placed.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
dfoth
@Sean_Page
You are correct that we can get the information, but we cannot place a text type of View Reference in Revit using dynamo. By text type I mean "6/A201", not a callout or section view reference, just "smart" text.
But if I'm incorrect, please share any solutions you may have as it would be greatly appreciated.  We've used dummy View Reference families where the text is actually just "dumb" text and then fed the dynamo collected information into the dummy view reference but that can be risky on big projects.
Sean_Page
Thanks for the clarification @dfoth, based on the image provided I thought we were just trying to get a list. Looks like this is also a post about it, and still does not seem possible as you noted as well.
https://forums.autodesk.com/t5/revit-api-forum/placing-a-view-reference/m-p/11722319/highlight/true#...
