Get property of a parent class?
CEdwardsUN5MX
CEdwardsUN5MX
I'm trying to figure out, with no success, how to get the Location property of a Coordination Model in Python.
The class is DirectShape, which is a child class of Element Class that does have a location property, but I've no idea how to get the property that should be inherited from it.
Can someone give me an idea how this is done?
jeremy_tammik
You could cast the DirectShape to an Element object and query its Location property. However, I doubt that will be of any use, since it is probably not populated at all, and hence will return null. Afaik, the only location information you can retrieve from a direct shape is via its geometry, e.g., vertices etc.
