Get PointAtParameter
using Autodesk.DesignScript;//.Geometry;
using Revit.Elements;
using Revit.GeometryConversion;
im cant use this method:
problem exactly in get .PointAtParameter
Point pt=Curve.PointAtParameter()
aignatovich
Hi!
What is your Curve object type? If it is Autodesk.Revit.DB.Curve (or any descendant type), you need to invoke Evaluate method: http://www.revitapidocs.com/2017.1/1145f18e-3e01-60df-e438-e176c38c3ce9.htm
Probably its
Autodesk.DesignScript.Geometry.Curve
because of in dynamo its Point.At.Parameter node and im want to use them in VisualStudio....
my_line_ - its Autodesk.DesignScript.Geometry  element
param_1 - its range of integer
im try do anythink here  (its still wrong):
public XYZ Evaluate(double parameter, bool normalized) ? - how i must to use it
foreach (var i in param_1)
Point pt=Autodesk.DesignScript.Geometry.Curve.PointAtParameter(my_line_, i)
in dynamo its looks like
BenoitE&A
Hey,
To find the parameter of a Curve in a point, project the point on the Curve :
IntersectionResult intersection = myCurve.Project(myPoint);
The parameter is given by :
double myParameter = intersection.Parameter;
If you have the parameter value v you can access to the point of the Curve where the parameter value is v :
Point myPoint = myCurve.Evaluate(v);
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Thank you @BenoitE&A for answer!
im find the solution
 Autodesk.DesignScript.Geometry.Line base_line = Autodesk.DesignScript.Geometry.Line.ByStartPointEndPoint(pt_1.ToPoint(), pt_2.ToPoint());
var param_1_pt = new List<Autodesk.DesignScript.Geometry.Point>();
foreach (int i in param_1_)
param_1_pt.Add(base_line.PointAtParameter(param_list[i]));
 here
in param_1_ - this list of      <doubles> from 0 to
