Get point from curve intersection
Tripler123
Tripler123
Hello, I'm trying to find a point that specifies the intersection of two lines. I have seen that there is a curve.Intersect (curve) that returns a SetComparisonResult. There is a possibility of finding an XYZ of that intersection or how you could do it.
public Result Execute(ExternalCommandData commandData,
                              ref string message,
                              ElementSet elements)
            UIApplication uiApp = commandData.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Document doc = uiDoc.Document;
            // Conduit selection
            ElementId conduitElementId = uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element).ElementId;
            Element conduitElement = doc.GetElement(conduitElementId);
            // Get curve conduit
            LocationCurve conduitCurveLocation = conduitElement.Location as LocationCurve;
            Curve conduitCurve = conduitCurveLocation.Curve;
            // Get points conduit
            XYZ startConduitCurvePoint = conduitCurve.GetEndPoint(0);
            XYZ endConduitCurvePoint = conduitCurve.GetEndPoint(1);
            // Beam selection
            ElementId beamElementId = uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element).ElementId;
            Element beamElement = doc.GetElement(beamElementId);
            // Get the beam inferior point y restar la mitad del diametro del elemento
            double beamInferiorPoint = beamElement.get_BoundingBox(doc.ActiveView).Min.Z - conduitElement.get_Parameter(BuiltInParameter.RBS_CONDUIT_DIAMETER_PARAM).AsDouble() /2;
            // Get curve beam
            LocationCurve beamCurveLocation = beamElement.Location as LocationCurve;
            Curve beamCurve = beamCurveLocation.Curve;
            // Get points beam
            XYZ startBeamCurvePoint = beamCurve.GetEndPoint(0);
            XYZ endBeamCurvePoint = beamCurve.GetEndPoint(1);
            // Get points Conduit
            XYZ startConduitPoint = new XYZ(startConduitCurvePoint.X, startConduitCurvePoint.Y, beamInferiorPoint);
            XYZ endConduitPoint = new XYZ(endConduitCurvePoint.X, endConduitCurvePoint.Y, beamInferiorPoint);
            // Get points Beam
            XYZ startBeamPoint = new XYZ(startBeamCurvePoint.X, startBeamCurvePoint.Y, beamInferiorPoint);
            XYZ endBeamPoint = new XYZ(endBeamCurvePoint.X, endBeamCurvePoint.Y, beamInferiorPoint);
            // Line to get the point (Z is equal for two Lines)
            Line conduitLine = Line.CreateBound(startConduitPoint, endConduitPoint);
            Line beamLine = Line.CreateBound(startBeamCurvePoint, endBeamCurvePoint);
            // Get the intersection point
            conduitLine.Intersect(beamLine);// TODO: Get the point
            return Result.Succeeded;
mhannonQ65N2
Use the overload of Intersect that returns an array of intersection results as an out parameter.
// At top of file:
using System.Linq;
var intersects = conduitLine.Intersect(beamLine, out var intersections);
if(intersects == SetComparisonResult.Disjoint)
	// They don't intersect;
	return Result.Failed;
var intersection = intersections.Cast<IntersectionResult>().First();
var point = intersection.XYZPoint;
Tripler123
Thanks, reading the information well I realized and solved it in the following way.
IntersectionResultArray intersectionResults = new IntersectionResultArray();
            List<XYZ> points = new List<XYZ>();
            SetComparisonResult result = conduitLine.Intersect(beamLine, out intersectionResults);
            if (result == SetComparisonResult.Overlap)
                foreach (IntersectionResult intersectionResult in intersectionResults)
                    XYZ point = intersectionResult.XYZPoint;
                    points.Add(point);
            TaskDialog.Show("title", points.Count.ToString() + $"{points[0]}");
leungkahocityu
Community Visitor
Community Visitor
sir,
can apply to linked element?  such as linked wall
praveen.cMXB2H
How can i find intersection point of wall and column.
@Tripler123
