Get planarface under element
mr.engineer.aec
Message 1 of 11
mr.engineer.aec
 Hi guys,
I want to get under planarface of pile cap.
Is there any method to get it from solid?
i can only get all planarface from solid 😞
Thank in advanced.
Replies (10)
Message 2 of 11
jeremytammik
Yes, of course.
It is very simple.
You say you know how to retrieve all the planar surfaces.
Well, then you can iterate over them and ignore all that are not horizontal, e.g., by applying a predicate method like this to the planar surface normal:
    public static bool IsVertical( XYZ v )
      return IsZero( v.X ) && IsZero( v.Y );
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/U...
Next, you can sort the remaining horizontal planar surfaces by the Z coordinate of their Origin property:
https://www.revitapidocs.com/2020/9671f9cf-6779-d6ca-8af4-91ac44b986ac.htm
The one with the lowest Z coordinate is presumably the one you are after.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 11
mr.engineer.aec
 Hi @jeremytammik
Thank for your reply.
I am still finding workarounds according to your instructions.
Hope you can help me next time.
Message 4 of 11
jeremytammik
Thank you for your appreciation. My pleasure entirely.
Jeremy Tammik
The Building Coder
Message 5 of 11
mr.engineer.aec
 Hi @jeremytammik
I solved my issue by your guide.
Now, i have new issue, hope you can help me.
I want to create floor from edgeloops of bottom face.
I get edgeloops but i can't curvearray to use create floor method.
How to get curvearray of bottom face ?
Thank in advance
               EdgeArrayArray curveloop = planarFace.EdgeLoops;
              //Floor newfloor = doc.Create.NewFloor(curveloop, true);
Message 6 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @mr.engineer.aec ,
try using the below code
Use GetEdgesAsCurveLoops() method
                Face f;
                IList<CurveLoop> curveLoops = f.GetEdgesAsCurveLoops() as IList<CurveLoop>;
                CurveArray CA = new CurveArray();
                foreach(CurveLoop CL in curveLoops)
                    CurveLoopIterator CLi = CL.GetCurveLoopIterator();
                    while(CLi.MoveNext())
                        CA.Append(CLi.Current);
I hope this helps.
Naveen Kumar T
Message 7 of 11
mr.engineer.aec
 Hi @naveen.kumar.t
thank for your reply.
I write code like you but after run, Bug is visible.
Can you hekp me to solve this issue ?
Many thanks
IList<CurveLoop> curveloop = planarFace.GetEdgesAsCurveLoops() as IList<CurveLoop>;
                                CurveArray curveArray = new CurveArray();
                                foreach(CurveLoop cl in curveloop)
                                    CurveLoopIterator cli = cl.GetCurveLoopIterator();
                                    while (cli.MoveNext())
                                        curveArray.Append(cli.Current);
                                    Floor newfloor = doc.Create.NewFloor(curveArray, true);
Message 8 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
The error shows with the curves you have , you can't create a floor. can you check whether you got the proper face curve array?
The face curves should help you to construct a floor.
check whether the curves are valid.
Naveen Kumar T
Message 9 of 11
mr.engineer.aec
 Thank @naveen.kumar.t
this is my bad. I solved.
Message 10 of 11
Revitalizer
the input curves are not sorted.
RevitAPI.chm says:
"[...]Face.GetEdgesAsCurveLoops
Orientations of the curves and curve loops match the orientations of the face's edges and edge loops. The order of the CurveLoops should be considered as arbitrary.[...]"
Edit:
Oops, seems that I didn't read it carefully.
Curves in CureLoops are sorted, returned CurveLoops List is not.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 11 of 11
mr.engineer.aec
 Hi @naveen.kumar.t
Is there any way to offset curve to create floor like under picture. inside red line is curve get from face as above.
I search CreateViaOffset Method, but i don't know how to use it yet.
Can you show me how to use this method ?
Thank in advanced
