Get Pipe Segment parameter and compare it to Project Pipe Segment
I'm trying to use the API to iterate through all the pipes in the model and tally the total length of different pipe sizes. I found some sample code here (http://help.autodesk.com/view/RVT/2014/ESP/?guid=GUID-B9C38F9B-A11B-4369-B879-0A641A3E725F) which reports the various pipe sizes for each Pipe Segment. I'm trying to add simple Total Length tallying piece to this to prove my concept but I am having trouble matching up the Pipe Segment Name from each pipe and the Segment.Name from the Global Pipe Segments. Here is my code:
BuiltInParameter pipeSegmentParam = BuiltInParameter.RBS_PIPE_SEGMENT_PARAM;
BuiltInParameter pipeLengthParam = BuiltInParameter.INSTANCE_LENGTH_PARAM;
// Get all pipes in the project
FilteredElementCollector collectorPipes = new FilteredElementCollector(doc);
collectorPipes.OfClass(typeof(Autodesk.Revit.DB.Plumbing.Pipe));
IEnumerable<Pipe> pipes = collectorPipes.ToElements().Cast<Pipe>();
FilteredElementCollector collectorPipeType = new FilteredElementCollector(doc); collectorPipeType.OfClass(typeof(Segment)); IEnumerable<Segment> segments = collectorPipeType.ToElements().Cast<Segment>(); foreach (Segment segment in segments) { StringBuilder strPipeInfo = new StringBuilder(); strPipeInfo.AppendLine("Segment: " + segment.Name); strPipeInfo.AppendLine("Roughness: " + segment.Roughness); strPipeInfo.AppendLine("Pipe Sizes:"); double dLengthFac = 12; // used to convert stored units, 304.8 for Imperial to Metric, 12 for Imperial foreach (MEPSize size in segment.GetSizes()) { double totalLength = 0.0; foreach (Pipe pipe in pipes) { Parameter pipeSegment = pipe.get_Parameter(pipeSegmentParam); double pipeSize = pipe.Diameter; if (pipeSegment.AsString() == segment.Name.ToString()) { if (pipeSize == size.NominalDiameter) { totalLength = totalLength + pipe.get_Parameter(pipeLengthParam).AsDouble(); } } } strPipeInfo.AppendLine(string.Format("Nominal: {0:F3}, ID: {1:F3}, OD: {2:F3}", size.NominalDiameter * dLengthFac, size.InnerDiameter * dLengthFac, size.OuterDiameter * dLengthFac)); strPipeInfo.AppendLine(string.Format("Total Length: {0:F3}", totalLength)); } TaskDialog.Show("PipeSetting Data", strPipeInfo.ToString()); break; }
When I run this, I get zero length for all pipe sizes in the dialog window even though I know I have pipes in the model with the corresponding pipe type. When I debug and inspect the values, I notice that the variable pipeSegment has a whole bunch of values but none of which appear to match the built in parameter RBS_PIPE_SEGMENT_PARAM that I am trying to get. This appears to cause my first if statement to always be false. So how do you find the Pipe Segment property on a pipe to compare it to the Pipe Segment names in the project? Or is there a better way to solve this?
I think I figured it out on my own. I found that if I retrieved the ElementId of the segment and compared it to the ElementId of the pipeSegment parameter, it seems to work. I also had to change the Built in parameter that reads the Pipe length to CURVE_ELEM_LENGTH.
Here is the tweaked section in my second foreach statement:
ElementId segmentSchTypeId = segment.Id;
ElementId pipeSegmentTypeId = pipeSegment.AsElementId();
if (pipeSegmentTypeId == segmentSchTypeId)
