Get parameter value in family document
tdaniel
tdaniel
I am a noob using the following code to get all parameters in my family document in Revit 2015.  I cannot find a way to get the actual value of the parameters.  Hope this is easy and that I'm overlooking something.  My ultimate goal is to search for a few specific family/shared parameters and return their values.  Any help would be greatly appreciated!
Document doc = this.ActiveUIDocument.Document;
            FamilyManager famMgr = doc.FamilyManager;
            foreach(FamilyParameter fp in famMgr.Parameters)
               StringBuilder paramInfo = new StringBuilder();
               bool isShared = false;
               try
                  Guid paramGuid = fp.GUID;
                  // following line will be reached only when parameter is shared parameter
                  isShared = true;
               catch (Autodesk.Revit.Exceptions.InvalidOperationException)
                  // This exception will be thrown when the parameter is not a shared parameter.
                  isShared = false;
               paramInfo.Append("Name: " + fp.Definition.Name + "; ");
               paramInfo.Append("Is Shared: " + isShared + "; ");
               paramInfo.Append("Is Instance: " + fp.IsInstance + "; ");
               paramInfo.Append("Value:  ");
               Trace.WriteLine(paramInfo.ToString());
               TaskDialog.Show("Parameter Info",  paramInfo.ToString());
tdaniel
found this code after posting the question!  Thanks Jeremy!
http://thebuildingcoder.typepad.com/blog/2009/11/family-parameter-value.html
