get parameter GUID directly from shared parameter file
Ning_Zhou
Message 1 of 9
Ning_Zhou
is parsing that text file the only way out?
seems Definition only have properties of Name, ParameterGroup, ParameterType, and UnitType; no GUID.
i'm writing a utility tool to check multiple files (RVT, RFA, RTE, RFT) against our standard SP file, so getting GUIDs from SP file is necessary step.
Replies (8)
Message 2 of 9
Mustafa.Salaheldin
Try this
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS5
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                   FilteredElementCollector collector = new FilteredElementCollector(CachedDoc);
                collector.OfClass(typeof(FamilyInstance));
                List<Element> els = collector.Cast<Element>().ToList();
                Element el = els.First();
                string parameter = el.LookupParameter(sharedParameterName).GUID.ToString();
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
if it satisfies your needs please mark this reply as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 3 of 9
Ning_Zhou
thanks Mustafa for your quick reply.
well, what i want is getting GUID directly from shared parameter file, not from any existing element, for instance
app.SharedParametersFilename = @"C:\SP.txt";
// get SP from SP file
DefinitionFile df = app.OpenSharedParameterFile();
DefinitionGroups dgs = df.Groups;
foreach (DefinitionGroup dg in dgs)
   foreach (Definition d in dg.Definitions)
      string n = d.Name;
      // how to get GUID from d?
Message 4 of 9
Mustafa.Salaheldin
Here you are the solution and don't forget to mark the reply as answer Smiley Wink
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
namespace RevitAddinCS2
            get
            get
            get
        #endregion
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            _cachedCmdData = commandData;
            if (CachedDoc.IsFamilyDocument)
                message = "The document must be a project document.";
            CachedApp.SharedParametersFilename = @"C:\shared.txt";
            DefinitionFile df = CachedApp.OpenSharedParameterFile();
            StringBuilder sb = new StringBuilder();
                sb.AppendLine(string.Format("Group Name: {0}", dg.Name));
                    if (d != null)
                        ExternalDefinition ed = d as ExternalDefinition;
                        sb.AppendLine(string.Format("Parameter {0} with Guid: {1}", ed.Name, ed.GUID.ToString()));
            if(sb.Length > 0)
                TaskDialog.Show("Revit", sb.ToString());
        #endregion
Smiley Wink
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 5 of 9
Ning_Zhou
right, downcasting is needed, thanks again Mustafa for your quick reply and solution!
Message 6 of 9
Revitalizer
no need to read the shared parameters text file, and also no need of FamilyInstances to get the Guid of a shared parameter.
From Revit 2016 on, there is a SharedParameterElement class, providing a GuidValue property.
So just get these Elements, detect the right one by its Name property and get its GuidValue.
That's all.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 9
Mustafa.Salaheldin
This is right. But as a shared parameter has been loaded into a document, information about it can be retrieved from the SharedParameterElement class.
So you will have to read it directly from the txt file.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 8 of 9
Revitalizer
you are right, he needs to read the SP text file in each case, to get the parameter guids to look for.
For each of the Revit files, he just needs to search for the SharedParameterElements of the guids.
By the way, nice to see somebody supporting others so much.
Kudo, too.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 9 of 9
Ning_Zhou
definitely Kudo for both of you!
yep, comparing GUID of txt file against GUID of SharedParameterElement from model is the whole idea, in fact, lots of duplicates (same name w/ different GUID) and redundant SPs (existed in model but not in txt file) already found using Revit Lookup, most likely from 3rd party content, model, etc.
