Announcements
Get Only Visible Elements in Linked Documents
I've been working on a plug-in that needs access to elements (e.g. Gridlines) that are in linked files. I have tried every suggested methods I could find online, but have only found a little success using the CustomExporter to Export a selected 3d view to a custom object. That at least allows me to access an array of all the elements in the documents. However, it seems there are a couple problems with this method.
  • CustomExporter.Export method requires a 3d View to work, even though the user may be working in a 2d view. In the 2d view I can see the elements, but no method I've tried will retrieve them using the current active view in that case (meaning I have to prompt the user to select one of the 3d views, which is clunky at best).
  • The list of elements returned includes all of the elements in each linked document, including in all the nested linked files. In the case of Gridlines, I have 28 visible lines in the document when I open it, but I end up with 174 in all of the documents. There seems to be no way to tell which Gridlines are the ones I want, as all 174 have a Visibility of Visible.
I'm using c# and Revit 2017 & 2018. Does anyone have any suggestions?
jeremytammik
Dear Nate,
Thank you for your challenging query.
It is an interesting question and not easy to solve, as you already mention.
Just as you say, the custom exporter is probably the easiest and most reliable way to go for 3D views.
Another easy and reliable piece of functionality that might help here is specifying the view in a filtered element collector.
Have you made use of that possibility? Can you make use of that?
Here are some discussions by The Building Coder on retrieving visible elements in various situations:
A few more techniques are mentioned in the topic group on retrieving elements using the FilteredElementCollector:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.9
Most interesting of all may be the methods implemented by Colin @Anonymous Stark in The Building Coder samples module CmdViewsShowingElements.cs:
It determines all views displaying a given set of elements.
He discusses them in more detail here:
I hope this helps.
Please let us know how you get on with this, and especially what solution you end up implementing.
Thank you!
Happy New Year!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
samsoncpwong
Dear Jeremy,
I follow the method under https://thebuildingcoder.typepad.com/blog/2013/08/determining-absolutely-all-visible-elements.html and try to collect all visible elements from linked document.
In my testing model, I have two walls highlighted in yellow below belong to a link file. Two elements detected through OnElementBegin. They are RevitLinkInstance. Returned ElementID should be ID in main document. Nothing returned through OnLinkBegin. How can I get the elementID of these two walls within the link document?
I test in Revit 2017. I trigger the custom export through below code:
Dim VBCol As New ElementsVisibleInViewExportContext(doc)
Dim CE As CustomExporter = New CustomExporter(doc, VBCol)
CE.IncludeGeometricObjects = False
CE.ShouldStopOnError = False
CE.Export(view3D)
Many thanks.
Samson
jeremytammik
Dear Samson,
Thank you for new question on this.
As far as I understand, your main question is how to determine the element id of the individual walls inside the linked document.
Please try selecting and snooping those elements using the new RevitLookup functionality for exploring linked elements:
https://thebuildingcoder.typepad.com/blog/2019/01/new-revitlookup-snoops-edge-face-link.html
I tried that recently myself, and it worked fine for me.
Then you can examine the RevitLookup source code to see out how to implement that for yourself.
I hope it works out.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
ameer.mansourWAK8Y
did you get solution to this?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
