Get Material Types
Get Material Types
Get Material Types
Hi folks,
I would like to be able to get the materials in the project and get their Material Class.2018-10-12_16-08-34.png
The code I've written is as follows.
FilteredElementCollector materials = new FilteredElementCollector(Global.doc()).OfClass(typeof(Material));
List<Element> materialList = materials.ToList();
But when I try to get i.e materialList[11].MaterialClass I am not able to retrieve its class. Eventhough I know its there.
There must be a specific way of casting the value.
I've tried casting like (Autodesk.Revit.DB.Material)materialList[11] but it didn't helped either.
Can anybody please help me to retrive MaterialClass please. Any advice is much appreciated.
jeremytammik
Have you installed RevitLookup?
https://github.com/jeremytammik/RevitLookup
You can use that to interactively explore the Revit database, its elements, their properties, and their mutual relationships.
That should enable you to resolve your issue yourself.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
Have you tried the below code??
Material mat;
string material_class=mat.MaterialClass.ToString();
Naveen Kumar T
Thank you this is very helpful.
