Get Level from Wall's Top Constraint Parameter
Hi Guys,
I am am trying to retrieve the Level object from a Wall's Top Constrain parameter. But I am not sure if this is posssible. Although having a look in the Revit Lookup I can get to that data.
Do you guys know if this is achiavable?
Here is my short method for know, (dont pay attention to the name of and the fact that is returning void)
   private void FilterDependantWallsOnHeight(double heightFilter, List<Wall> walls)
            for (int i = 0; i < walls.Count; i++)
                Parameter TopConstrain = walls[i].get_Parameter(BuiltInParameter.WALL_HEIGHT_TYPE);
               ElementId id= TopConstrain.AsElementId();
Thanks, Nicholas
jeremytammik
Everything that RevitLookup does, you can do in your add-in too.
Your method looks like a good start.
Keep going  🙂
Jeremy Tammik
Developer Technical Services
The Building Coder
