Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get keynoteTable file location
2 REPLIES 2
ashleyB5APU
201 Views, 2 Replies
I'm struggling with a seemingly simple problem. In python, using the Revit API, I need to get the keynote table file path.
I've tried using KeynoteTable.GetKeynoteTable(Document).GetExternalResourceReferences() which returns a dictionary. I can't however get the ExternalResourceReference objects, to access the property called InSessionPath. Is there a better way to do this?
Anyone delt with this issue before?
2 REPLIES 2
GaryOrrMBI
in reply to: ashleyB5APU
The clues were there in the other thread that you posted in (via the post that was linked from that)... but it was messy to decipher so...
If just getting the path to the Keynote file is actually what you're after then try:
[yourkeynotetable].GetExternalFileReference
this will return an ExternalFileReference
from that you can use:
[extfileref].GetPath and/or [extfileref].GetAbsolutePath depending on your needs.
those methods will return a ModelPath element
then you use ModelPathUtils.ConvertModelPathToUserVisiblePath([your returned model path here]) to convert the ModelPath element into a user readable string as/if required.
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
ashleyB5APU
in reply to: GaryOrrMBI
Hi Gary, that worked perfectly. Thank you for the reply, much appreciated.
Rail Community
