Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I'm struggling with a seemingly simple problem. In python, using the Revit API, I need to get the keynote table file path.
I've tried using KeynoteTable.GetKeynoteTable(Document).GetExternalResourceReferences() which returns a dictionary. I can't however get the ExternalResourceReference objects, to access the property called InSessionPath. Is there a better way to do this?
Anyone delt with this issue before?
Solved by GaryOrrMBI. Go to Solution.
Hi Gary, that worked perfectly. Thank you for the reply, much appreciated.
