Get floor lines except span direction
baekdi
baekdi
Hi, I want to get floor lines except span direction.
I have a floor that have 4 edge lines and a span direction.
And I get lines with this code.
Sketch floorSketch = doc.GetElement(selectedFloor.SketchId) as Sketch;
List<ModelCurve> floorModelCurves = new List<ModelCurve>();
foreach (ElementId id in floorSketch.GetAllElements())
    Element el = CommonVariable.CurrentDocument.GetElement(id);
    if (el is ModelCurve)
        floorModelCurves.Add(el as ModelCurve);
floorModelCurves's count is 5 including span direction.
I tried to except span direction using model line's Name ("Span Direction Edge")
But in Revit Korean version, the name is not same with in English Version.
How can I determine the model line is 'span direction' or not?
jeremy_tammik
Wouldn't it be easier to obtain the floor edges directly from the floor geometry, instead of its sketch? You could retrieve the floor solid, navigate to the top face (facing upwards) and query it for its face and edges. That ought to provide exactly what you are asking for. Have you used RevitLookup to explore the various floor properties and geometry? The newest release of RevitLookup includes new functionality for geometry visualisation:
jeremy_tammik
Here are two articles by The Building Coder on obtaining the top faces of a wall that might help:
ctm_mka
@jeremy_tammikunfortunately element geometry tends to return only the joined solid, which will result in extra lines they may not want.
@baekditwo options, first instead of looking for modelcurves first, look for Model Lines, and filter by Name, heres the Revit Lookup result for a similar slab:
Second option revise your code to look at the profile which only returns the four lines:
Sketch floorsketch = _doc.GetElement(testfloor.SketchId) as Sketch;
foreach (CurveArray curvarr in floorsketch.Profile)
    foreach (Line test in curvarr)
        floorModelCurves.Add(test);
One caveat to both methods you should be aware of, any interior boundaries will show up in the list.
Moustafa_K
I believe span direction curve does not define slop direction. thus we can take this parameter as medium to define the curve is span curve or not.
see this example
var modelLines = floor.GetDependentElements(new CurveElementFilter(CurveElementType.ModelCurve));
List<Curve> curves = new List<Curve>();
foreach (var modelCurveId in modelLines)
    var modelCurve = Doc.GetElement(modelCurveId) as ModelCurve   ;
    var canDefineSlop = modelCurve.get_Parameter(BuiltInParameter.CURVE_IS_SLOPE_DEFINING) != null;
    if(canDefineSlop)
        curves.Add(modelCurve.GeometryCurve);
    else
        // ignore Span direction curve
let us know your findings
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
baekdi
I solved this problem with your second option.
And I get curve's Model line ID by curve.Reference.ElementId because I need Model Line id.
thank you all!
