Get filepath of linked CAD file (non-rvt file)
dante.van.wettum
dante.van.wettum
I am trying to retrieve the filepath of linked CAD files that are linked in the model. I try to do this specifially for all linked files that are not revit linked models.
But so far it seems like i am not capable of retrieving the filepath of a linked (non-rvt) file (.dwg's and such).
Is it possible to get the file path of linked files trough API ?
FilteredElementCollector col = new FilteredElementCollector(doc).OfClass(typeof(CADLinkType));
            foreach (Element el in col)
                try
                    CADLinkType link = doc.GetElement(el.Id) as CADLinkType;
                    bool isLinkedFile = link.IsExternalFileReference();
                    if (isLinkedFile == true)
                        ExternalFileReference exFiRef = link.GetExternalFileReference();
                        ModelPath path = exFiRef.GetPath();
                        string pathString;
                        if( path.ServerPath == true)
                            pathString = path.CentralServerPath;
                        else
                            pathString = path.ToString();
                        TaskDialog.Show("Path", "RefType: "+exFiRef.ExternalFileReferenceType.ToString() + Environment.NewLine+
                                                "Path: " + pathString);
                catch (Exception ex)
                    TaskDialog.Show("Error", ex.Message);
dante.van.wettum
finally found it by using : ModelPathUtils.ConvertModelPathToUserVisiblePath(exFiRef.GetAbsolutePath());
apparently i was looking in the wrong places (members of ExternalFileReference, ImportInstance, and even looking into TransmissionData).
i just didnt came up with looking for ModelPathUtils.
jeremytammik
Dear Dante,
Thank you for your query and sharing your solution.
Yes, indeed, as @Revitalizer keeps pointing out as well, the Revit API Util classes are often overlooked:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.52
Thank you for bringing up yet another important use case.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
