Get Face From PickObject(ObjectType.Face)
Dear everyone, I pick a face by this:
Reference rf = sel.PickObject(ObjectType.Face);
How can I retrieve Face f from reference rf? Thank you.
matthew_taylor
Hello @Anonymous,
Searching the SDK yields this example:
Reference faceRef = m_document.Selection.PickObject(ObjectType.Face, _
  new PlanarFaceFilter(m_document.Document), _
  "Please pick a planar face to set the work plane. ESC for cancel.");
GeometryObject geoObject = _
  m_document.Document.GetElement(faceRef).GetGeometryObjectFromReference(faceRef);
PlanarFace planarFace = geoObject as PlanarFace;
If you haven't downloaded the SDK, you should now. (see here) Smiley Happy
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
jlpgy
Hi, thanks for you suggestion.
Now I have a further question:
How to obtain a geometry object from a LINKED element.
I use PickObject() with ObjectType.PointOnElement to get a Reference object.
If I pick an Element in the host (current/main/master, whatever you call it) document,
<elemInHostDoc>.GetGeometryObjectFromReference(refPickedInHostDoc)
 The above method works just fine for me.
As I had tested: ObjectType.PointOnElement can pick both in host document and in linked document.
If I pick an Element in a linked document, for example, I click a surface of a rectangular Duct, API gave me back a Reference object of which the ElementReferenceType property is SURFACE.
I had tried calling GetGeometryObjectFromReference in the following 2 ways:
1.
<elemInLinkDoc>.GetGeometryObjectFromReference(pickedRef)
// throw exception : The id of this element is not same as that referenced by reference
Parameter name: reference
2.
<rvtLinkInstanceElement>.GetGeometryObjectFromReference(pickedRef)
// returns <null>
Sooo, How can I obtain a geometry object from a link Element?
Thanks !
单身狗;代码狗;健身狗;jolinpiggy@hotmail.com
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @jlpgy ,
try using the below link
selecting-a-face-in-a-linked-file
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
As the link:
https://forums.autodesk.com/t5/revit-api-forum/check-out-the-self-paced-guide-my-first-plug-in/m-p/3...
with this statement:
"Note on 5/11/2018: My First Plug-in is being migrated to Knowledge Base (similar to this forum). Right now, the marketing URL is not working. In a mean time, you can access here:
https://knowledge.autodesk.com/community/collection/my-first-autodesk-revit-plug
Still work in progress. Working on updating all the links, to the latest three releases, etc."
However as the picture show the link is "Not Found"?!
Could someone give a hand? thx~
matthew_taylor
Try this one:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/my-fi...
Cheers,
-Matt
