Get Elements Hidden lines geometry
nasirodin
nasirodin
Hi Everyone,
I'm trying to extract a list of geometries from a flex duct that partially obscured by another element. Query elements geometries using "element.get_Geometry()" method retrieves all lines including the hidden lines.
is there any way to distinguish geometries related to the hidden lines?
Thanks for your help!
jeremytammik
Check all the lines' GraphicsStyleId property:
https://www.revitapidocs.com/2020/4103f148-957e-3f44-9ccd-a5ed6702c689.htm
Jeremy Tammik
Developer Technical Services
The Building Coder
nasirodin
thanks for the reply,  unfortunately, all the lines' GraphicsStyleId property has the same value. even those lines obscured by the duct ( denoted in the following picture as hidden lines)
I'm querying geometries as follows, should I try different options?
var geometries = element.get_Geometry(new Options() { View = _document.ActiveView });
jeremytammik
The only other option of interest that comes to mind is IncludeNonVisibleObjects:
https://www.revitapidocs.com/2020/0d277b80-d5e5-1151-d413-b0899da0976f.htm
However, that is apparently not required in this case...
Jeremy Tammik
The Building Coder
