Get elements from schedule
Extraneous
Advisor Advisor
Extraneous
I want to get all elements that shows in ViewSchedule. Jeremy offers simple solution: FilteredElementCollector(document, ViewSchedule.Id) - because "Schedule is a View".
But this don't work! Collector return more elements that Schedule includes!
For example, document with simple "document-level macro" in attachment: 3 rebars in model, 1 rebar in schedule (filter by Mark). Macro returns 2 pcs!
I try to get ScheduleDefinition and list of ScheduleFilters, and reproduce the filtering. But if there is a filter on the calculated value - it will not work...
It is API issue, or error in my code?
Alexander Zuev
In BIM we trust
Facebook | Linkedin | Telegram
FAIR59
It is a API/Revit issue ( not your code).
In my answer to this question https://forums.autodesk.com/t5/revit-api-forum/quick-way-of-counting-rows-in-a-schedule/td-p/5800112 I found a workaround to get the elementId's for a given row on a Schedule. You can iterate through all the rows to get all the elements Visible in the Schedule.
