Get element quantity and unity
Hi there,
I saw on the building coder a way to get material quantity, but on of the links on this article is broken, so i can't get "scott's AU material class". I need to get material's quantity and unity (like 10 m3 of concrete, 50m2 of wood floor, etc).
i searched on building coder during a couple of hours but only found one good article with a broken link 😞 can someone give the good link or another idea to get material quantity and unity? i need it for a global cost calculator plugin.
jeremytammik
Dear Supamiu,
Thank you for discovering the broken links in that old article.
I added some new information, uploaded Scott's old AU 2009 class handout, and also point to an updated version from AU 2011:
http://thebuildingcoder.typepad.com/blog/2010/02/material-quantity-extraction.html#2
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
the link file:////a/doc/au/2009/doc2/AU09_CP222-3_Analyze_Geometry_Revit_API.pdf doesn't work too. I'm going to have a look on 2011 version of this class, thanks for your help.
jeremytammik
Dear Supamiu,
Sorry for the broken link. I fixed it now:
I hope this one works for you.
In any case, the Revit 2011 material is probably preferrable over the 2009 information, isn't it?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
