Get DesignOptions in DesignOptionSet via API? (R22)
eric.isaac2KKE9
eric.isaac2KKE9
Is there a way to determine which DesignOptions are in a given DesignOptionSet via the API in Revit 2022?
I'm able to get a list of the DesignOptions, and a list of the DesignOptionSets, but I don't know how to correlate them.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @eric.isaac2KKE9 ,
Try using this below sample code
 //Filter Design Option Sets Present in the Project
FilteredElementCollector designOptionSetcollector = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_DesignOptionSets).WhereElementIsNotElementType();
ElementFilter eFilter = new ElementCategoryFilter(BuiltInCategory.OST_DesignOptions);
foreach(Element e in designOptionSetcollector)
   string designOptionSet_Name=e.Name;
   //Get all Design Options present in each DesignOptionSet
    IList<ElementId> designOptionList = e.GetDependentElements(eFilter);
    foreach(ElementId eid in designOptionList)
          string designOptionName=doc.GetElement(eid).Name;
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
eric.isaac2KKE9
This did what I needed, thank you @naveen.kumar.t!
