get ceiling material in room
CADdaddy.com
CADdaddy.com
Hi all,
I'm using the SpatialElementGeometryCalculator to access the 3D faces within a room.  It finds the walls, floor, and the floor above but the ceiling 3D face seems to be completely ignored.  Anybody know how to acquire the ceiling(s) in a room?  Better yet, is there a way to acquire everything that is in a room using the boundries provided by the SpatialElementGeometryCalculator?
James
jeremytammik
Dear James,
Thank you for your query.
Have you taken a look at the RoofsRooms SDK sample?
It detects whether a room has a roof.
You may be able to adapt it for ceilings also.
Alternatively, you should be able to shoot a ray upwards from the floor of the room using a ReferenceIntersector, and the ceiling should be the first element you hit.
http://www.revitapidocs.com/2017/36f82b40-1065-2305-e260-18fc618e756f.htm
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
Dear James,
To address your second question how to "acquire everything that is in a room":
The ElementIntersectsSolidFilter class should help with that:
http://www.revitapidocs.com/2017/19276b94-fa39-64bb-bfb8-c16967c83485.htm
You could create a solid representing the room shape and retrieve all elements intersecting that solid.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
