Get Categories
Get Categories
HI Guys im trying to get a list of category similar to visibility graphics options as shown in the image
but for some reason im get extra items. How do i filter them?
 foreach (Category cat in _doc.Settings.Categories)
                categories.Add(cat);
            foreach(Category category in categories)
                if (category.CategoryType == CategoryType.Model)
                    TreeNode treeNode = new TreeNode(category.Name);
                    foreach (Category sub in category.SubCategories)
                            treeNode.Nodes.Add(sub.Name);
                    treeView1.Nodes.Add(treeNode);
TripleM-Dev.net
Good one, never noticed, I display them in a DataGrid and never compared.
Maybe a couple of things:
Check if it's a builtin Category (Try to convert to a BuiltinCategory Enum)
If true then compare against you're own "internal use only list names".
The names seem to consist of the Function Layers + Cut/Surface pattern names.
And see if those are the only ones?...
Function LayersFunction LayersIllegal charsIllegal chars
I'm going to include an additional column in mine, thanx for noticing.
Add Column for those!Add Column for those!
- Michel
Sean_Page
See here as well.
https://forums.autodesk.com/t5/revit-api-forum/how-to-get-category-list/td-p/4477699
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
TripleM-Dev.net
Hi @Sean_Page ,
That solution would not retrieve all Categories as displayed in the Object styles, as asked by OP.
However, good addition, added it also to my addin for added information.
As you can see below only slabedges can be bound to project parameters, several other builtin can't and neither user created subcategories.
CategoriesCategories
- Michel
