Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get BuiltInParameter from element after FindInserts
3 REPLIES 3
andresep82
675 Views, 3 Replies
hello again,
i can get the parameter with this code
                            foreach (Element win in PickWindows)
                                ElementId id = win.GetTypeId();
                                ElementType type type_win = doc.GetElement(id) as ElementType;
                                Parameter param_height= type_win.get_Parameter((BuiltInParameter.WINDOW_HEIGHT));
                                parametro_height = param_height.AsDouble();
                                //TaskDialog.Show("Height", parametro_height );
but when i try get the same parameter afte FindInserts  always return 0
  foreach (Wall w in pickedElements)
                        IList<ElementId> inserts = (w as HostObject).FindInserts(true, true, true, true);
                        foreach (ElementId id in inserts)
                            Element e = doc.GetElement(id);
                            //GetElementLength(e);
                            Parameter param_HEIGHT = e.get_Parameter((BuiltInParameter.WINDOW_HEIGHT));
                            parametro_HEIGHT = param_HEIGHT.AsValueString();
                            TaskDialog.Show("Areas", "Elements = " + e.Name+"-"+ parametro_HEIGHT );
The name of element is ok but..... the height always 0, any suggestion?
thanks¡¡¡¡¡
3 REPLIES 3
Revitalizer
in reply to: andresep82
depending on the Family, there is a type parameter having a valid value.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Revitalizer
andresep82
in reply to: Revitalizer
thanks¡¡¡
nex time i find better.....
Rail Community
