Get Boundary Elements in RVT 16
rvtquestions
rvtquestions
I am trying to test out and learn more about the room/space and boundary classes for the Revit API. I tried debugging an example I found from Jeremy:
Under the section:
GetBoundarySegmentElement External Command Implementation
http://thebuildingcoder.typepad.com/blog/2013/10/determining-a-room-boundary-segment-generating-elem...
However debugging gives me the error:
List<Room> rooms = new List<Room>(
sel.Elements.Cast<Room>() );
Error CS1061 'Selection' does not contain a definition for 'Elements' and no extension method 'Elements' accepting a first argument of type 'Selection' could be found (are you missing a using directive or an assembly reference?) GetBoundarySegmentElement
foreach( BoundarySegment seg in loop )
Element e = seg.Element;
Severity Code Description Project File Line Suppression State
Warning CS0618 'BoundarySegment.Element' is obsolete: 'This property is deprecated in Revit 2016. Use ElementId instead.' GetBoundarySegmentElement
Any help would be greatly appreciated to help get this running for RVT 16. Thank you!
jeremytammik
You need to migrate the code to the new API.
That is trivial.
First time migration, including some reading of 'What's New' information: 20 minutes, maybe.
Next time: less than five minutes.
 Have you searched for an answer at all?
I must have answered this dozens of time already.
Surely some trace must remain somewhere?
http://thebuildingcoder.typepad.com/blog/migration
http://thebuildingcoder.typepad.com/blog/2014/04/whats-new-in-the-revit-2015-api.html
http://thebuildingcoder.typepad.com/blog/2015/06/cnc-direct-export-wall-parts-to-dxf-and-sat.html#20...
Have fun!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
