Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Get base and top level of a selected column.
3 REPLIES 3
2908 Views, 3 Replies
Hello everyone,
I'm a Revit API newbie. How can I get base and top level of a selected column? The following codes don't work:
UIDocument uidoc = new UIDocument(Document);
Document doc = uidoc.Document;
ElementSet col = uidoc.Selection.Elements;
foreach(Element e in col)
Parameter pB = e.get_Parameter(BuiltInParameter.FAMILY_BASE_LEVEL_PARAM);
Parameter pT = e.get_Parameter(BuiltInParameter.FAMILY_TOP_LEVEL_PARAM);
TaskDialog.Show("Column Levels", pB.AsString()+" & "+pT.AsString());
I'm using Revit One Box 2013. Thank for any help!
3 REPLIES 3
jeremytammik
Dear annp_mth,
As a newbie, I would recommend installing and using RevitLookup before you try anthing else at all.
If you do not know how, please work through the getting started materials before that:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Once you have RevitLookup up and running, you can insert a column manually through the user interface and explore its parameters in RevitLookup to answer this question and the unending list of other questions that arise on a daily , hourly or even per-minute basis during any add-in development.
For a more powerful approach still, install an interactive interpreted programming shell for deeper and more intimate database exploration, e.g. like this:
http://thebuildingcoder.typepad.com/blog/2013/11/intimate-revit-database-exploration-with-the-python...
Good luck, and have fun!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
in reply to: jeremytammik
Hello Jeremy,
Your blog at TheBuildingCoder is one of my favourite blogs about Revit API. The 2 built in parameters in my codes were found out by using Snoop Current Selection. After reading your reply, I've studied deeper and found out why I were wrong. My new code doesn't look professionally but it worked (C# is not my field):
            ElementSet colcot = uidoc.Selection.Elements;
            foreach(Element e in colcot)
				Element mB = doc.GetElement(pB.AsElementId());
				Element mT = doc.GetElement(pT.AsElementId());
				TaskDialog.Show("aaa",mB.Name+"&"+mT.Name);
 Thank you very much! 🙂
jeremytammik
Dear annp_mth,
Great!
Thank you very much for the appreciation!
I am glad you find the blog useful, and are using RevitLookup.
Your code looks perfectly fine to me.
Congratulations on solving it!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
