The Assembly Code can be found from the FamilyParameter and the only way i have found to do this is to lookup the assembly code text file. You can easily do this when opening families from a document or insiode a project, pls tell me there is a less convoluted method? not Revit lookup, it tells you yeah just use Assembly Description.
