get area formula
get area formula
get area formula
I use "BuiltInParameter.HOST_AREA_COMPUTED" to get the area of element,
but could it possible to show out the formula of the calculation,
thanks for the reply!
jeremytammik
I assume this is more than just a simple formula... it probably depends on numerous factors, doesn't it?
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks for the reply.
I'm trying to show how it compute the area of each components.
If the shape of the component is regular like circle or rectangle, then that'll be no problem.
But is there any approach to show the formula in case the component is irregular?
jeremytammik
not that I am aware of, sorry.
Jeremy Tammik
The Building Coder
I recall from Calculus 101 class --- many, many years ago, that there is a general method for calculating the area of an irregular object using calculus. Unfortunately, I have forgotten the method, but this bit of info may help set you to search in the right direction.
Thanks for the direction, I will check it out.
