Get all Views that accept View Template
Message 1 of 8
Hi, i'm trying to get all Views that has View Template parameter. However, my code gives me extra data that i don't need (encircled in red). can someone point me to the right direction?. i can't find solution in by Googling or my googling skills really hates me 😞
i try this two below code but return the same:
this eliminate those data that i don't want. however, looks like it's not efficient way
Replies (7)
Message 2 of 8
jeremytammik
I cannot guarantee that what you are doing achieves what you want at all.
However, just looking at what you are doing with your code, here are a couple of suggestions:
You can use RevitLookup and other Revit database exploration tools to explore why this sometimes works and sometimes does not:
You can definitely make your code more concise, readable and effective in various ways.
Here is a suggestion for some improvement:
    /// <summary>
    /// Return all views with a
    /// "View Template" parameter
    /// </summary>
    static IEnumerable<View> GetViewsWithTemplate(
      Document doc )
      BuiltInParameter bip_t
        = BuiltInParameter.VIEW_TEMPLATE;
      FilteredElementCollector views
        = new FilteredElementCollector( doc )
          .WhereElementIsNotElementType()
          .OfClass( typeof( View ) );
      IEnumerable<View> views_w_t = views
        .Where( v
          => null != v.get_Parameter( bip_t ) )
        .Cast<View>();
      return views_w_t;
One possible reason for the differences may be that several different built-in parameters are used for the "View Template" property, e.g., BuiltInParameter.VIEW_TEMPLATE as well as BuiltInParameter.VIEW_TEMPLATE_FOR_SCHEDULE.
Maybe it is not sufficient to check only whether the parameter exists on the view, but also whether it has a valid non-zero value.
In any case, the parameter checking can be further speeded up by using a parameter filter to avoid the costly .NET or LINQ post-processing of results.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
FAIR59
I don't think there is a direct solution. But .. if you can apply a ViewTemplate to a view, you can also enable Temporary View Properties, and vice versa.  So .. all the views that CanUseTemporaryVisibilityModes, will accept a View Template.
IEnumerable<View> views = new FilteredElementCollector(doc)
				.OfClass(typeof(View))
				.Cast<View>()
				.Where(v1=> !v1.IsTemplate)
				.Where(v1=> v1.CanUseTemporaryVisibilityModes());
Message 4 of 8
Hi, Jeremy thanks for always being helpful i'll try this and get back to you what's my result.
i know my code is messy 🙂 i'm still searching some ways how to improve in writing a code.
Message 5 of 8
Hi. this works like what i want! however, this eliminates the view schedule which has View Template parameter so i just add view schedule in the list and cast it to it's base class to get the .IsTitleblockRevisionSchedule properties to gets rid of Revision Schedule that i'am getting on my first code.
Here is my result. comment in my code is very much appreciated for improvement
thanks to both of you  @jeremytammik @FAIR59  for helping 🙂
Message 6 of 8
jeremytammik
Thank you very much for your appreciation and sharing the solution.
Please do not post screen snapshots of code, because that makes it much harder to copy and paste the code, and also for Internet search engines and human beings to discover it at all.
Jeremy Tammik
The Building Coder
Message 7 of 8
jeremytammik
You can avoid a performance hit caused by instantiating a new List, copying part of your IEnumerable collection into it, thus duplicating information, repeated checking of properties and classes, and also avoid some code duplication like this:
    /// <summary>
    /// Predicate for views with template for
    /// GetViewsWithTemplate
    /// </summary>
    static bool ViewHasTemplate( View v )
      return !v.IsTemplate
        && (v.CanUseTemporaryVisibilityModes()
          || ((ViewType.Schedule == v.ViewType)
            && !((ViewSchedule) v).IsTitleblockRevisionSchedule));
    /// <summary>
    /// Return all views with a "View Template" parameter
    /// </summary>
      Document doc )
        .Cast<View>()
        .Where( v => ViewHasTemplate( v ) )
        .OrderBy( v => v.Name );
      return views_w_t;
Jeremy Tammik
The Building Coder
Message 8 of 8
Awesome! thanks again for the feedback on my code. it really helps me to improve
cheers!
