Get all room names from one plan view and change the parameter of a room
Message 1 of 8
Hello, right now I am working on a project, which should get the roomnames from a plan view and compare each room name with a database. If the roomname if found in the database, the parameter in the room called "IS_IN_DATABASE" should be updated with "YES"
Unfortunately  I have no Idea, how to get the roomnames from one plan view...
I found this post: https://forums.autodesk.com/t5/revit-api-forum/how-to-retrieve-rooms-filtered-by-level/td-p/6627076
but it does not work because I always get a exception:
viewId is not a view.
Parameter name: viewId
Replies (7)
Message 2 of 8
 FilteredElementCollector room_collector = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Rooms).WhereElementIsNotElementType();
                IList<ElementId> room_eids = room_collector.ToElementIds() as IList<ElementId>;
                foreach(ElementId eid in room_eids)
                    Room R = doc.GetElement(eid) as Room;
                    if(R.Level.Name=="Level 1" || R.Level.Name=="Level1")
                       string s=R.Name;
Message 3 of 8
Thank you so much,
I will look into it 😉
Message 4 of 8
thank you, so far I get every room in one level, that is exactly what I wanted, now all I need is to change a rooms parameter...
Do you know how to do that? 🙂
Message 5 of 8
                        ParameterSet P_set = R.Parameters;
                        foreach(Parameter p in P_set)
                            if(p.Definition.Name.Equals("Your parameter name"))
                                p.Set("your parameter value");
Message 6 of 8
Thank you for your help!
Can I also use this logic for custom parameter ("parameter I defined")?
Message 7 of 8
I guess it will work for custom parameters also.
Message 8 of 8
jeremytammik
This same question is also discussed o StackOverflow:
https://stackoverflow.com/questions/50246737/get-all-room-names-from-one-plan-view-and-change-a-para...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
