Get all elements in a project that have a parameter with a value.
I have this code.
ParameterValueProvider pvp = new ParameterValueProvider(new ElementId(5539));
FilterStringRuleEvaluator fsre = new FilterStringEquals();
FilterRule fRule = new SharedParameterApplicableRule("sharedparameter");
ElementParameterFilter filter = new ElementParameterFilter(fRule);
FilterRule fRule2 = new FilterStringRule(pvp, fsre,"",false);
ElementParameterFilter filter2 = new ElementParameterFilter(fRule2);
FilteredElementCollector col = new FilteredElementCollector(doc).WhereElementIsNotElementType().WherePasses(filter).WherePasses(filter2);
This code selects all elements in the project that have the specified shared parameter and where the value is "". But I'm looking for the inverse of this. Getting all elements that have the shared parameter and has some value. Is there some way to inverse the FilterStringRule?
Revitalizer
ElementParameterFilter has a constructor with a boolean parameter for inversion.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
matthew_taylor
Hi @Anonymous,
A lot of the filters have overloads that allow the filter to be 'inverted'. That's a good place to start.
To be honest, I think you'll need to approach your issue in a slightly different way. The filter you are trying to implement will return elements where the parameter has no value at all, that is, parameter.HasValue = false.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Yeah you are completely right I was looking for something like that but completely missed in the documentation
juancalvoferrandiz
Very interesting theme.
I'm trying to do something similiar but with no result:
I understand that with your code you must know the ID of the parameter ("5539").
I'm trying to do with the name and value 1/0 (yes / no parameter).
I know how to do it with a BuiltInParameter but no how to do it with a shared parameter:
// Built in Parameter
            BuiltInParameter testParam = BuiltInParameter.FUNCTION_PARAM;
            ParameterValueProvider pvp = new ParameterValueProvider(new ElementId((int)testParam));
            FilterNumericEquals fnrv = new FilterNumericEquals();
            FilterIntegerRule paramFr = new FilterIntegerRule(pvp, fnrv, ruleValInt);
            ElementParameterFilter epf = new ElementParameterFilter( paramFr );
            FilteredElementCollector doors = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors).WherePasses(epf); ;
            doors.OfClass(typeof(FamilyInstance));
// Shared Parameter ??
Parameter parameter = data.GetParameters(LabConstants.SharedParamsDefFireRating);
            ParameterValueProvider pvp = new ParameterValueProvider(new ElementId((int)parameter));
Any help is wellcome. Thanks.
Good afternoon.
matthew_taylor
Hi @juancalvoferrandiz,
You are best starting a new topic.
Cheers,
-Matt
