Get access to Revit Project Browser tree via Win32 api calls
ebrown1029
ebrown1029
Trying to get access to the Revit Project Browser tree. so I can traverse and act on desired tree nodes. Using Spy++ to get class id as highlighted below. Then trying to SendCommand to get the root of the tree.... its returning 0; I also tried the SendCommandOn the parent window and it also failed.
Can anyone help?
The treeRoot variable in line:
int treeRoot = SendMessage((int)hWnd, TVM_GETNEXTITEM, TVGN_ROOT, IntPtr.Zero);"
below is returning 0;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
  Process[] processes = Process.GetProcessesByName("Revit");
  if (0 < processes.Length)
     IntPtr mainWindowHandle = processes[0].MainWindowHandle;
     EnumChildWindows(mainWindowHandle, winEnumCallBack, IntPtr.Zero);
   return Result.Succeeded;
static bool winEnumCallBack(IntPtr hWnd, IntPtr lParam)
   StringBuilder className = new StringBuilder(100);
   IntPtr result = GetClassName(hWnd, className, className.Capacity);
   if (className.ToString() == "Afx:0000000140000000:b:0000000000010003:0000000000000006")
// treeRoot returning 0 - Help !!!!!
   return true;
jeremytammik
Dear Ebrown,
Thank you for your query.
Yes, the project browser window and its tree view appear to be non-trivial to find.
I am appending a screen snapshot of what I see in Spy++.
Based on that, I would search all Revit child windows whose caption begins with "Project Browser - ".
I would ignore the window class name if that does not lead to the desired result.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
