Get a selected set of parameter values
jaboone
jaboone
I can collected some elements in revit easily enough, but how can I filter those objects to determine a specifc parameter in a selected id object?  Specificly a electrical outlet.
      Double ls = 0;
      ICollection<ElementId> selectedIds = uidoc.Selection.GetElementIds();
      ICollection<ElementId> selectedElecIds = new List<ElementId>();
      foreach (ElementId id in selectedIds)
         Element elements = uidoc.Document.GetElement(id);
         if (elements is )  //THIS IS WHERE PROBLEM IS:  what is filter name to get a specific family member and/or a specific parameter name
            selectedIds.Add(id);  //selectedWallIds.Add(id);
            ls = Convert.ToDouble(elements.GetParameters("Watts"));
Thanks in advance for any help.
Learning as I go
Moustafa_K
it can be through different ways, but you can try this to match your code sequence
                if (elements.get_Parameter(BuiltInParameter.ALL_MODEL_FAMILY_NAME) != "XxX") continue;
let us know more if this is not what you need. as well as if it works.
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
rosalesduquej
Hi James,
Since you are learning with the Development of Revit I will refer you to read a bit more about Parameters in the API. http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-E0F304BC-07B8-461E-8FB2-234106951B0A
In there you will find also code in order to get the selected element parameters
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-D003803E-9FA0-4B2B-AB62-7DCC3A503644
Hope this helps,
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
jaboone
Sorry have not had time to follow up since I had to jump back on some paying jobs.
Learning as I go
