GeometryObject layer name
Using the code:
foreach (GeometryObject geometryObj in dwg.get_Geometry(new Options()))
I can loop the objects of the linked cad file. My problem is that I want to get the layer name  of the object.
Thanks & Regards
Sanjay Pandey
jeremytammik
Dear Sanjay,
Revit does not use layers.
I do not believe that a GeometryObject can be queried for that, or even has such a concept.
You might be able to open the original DWG file using AutoCAD.NET and analyse that instead.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
FAIR59
the information is contained in the GraphicalStyle element:
GraphicsStyle gStyle = document.GetElement(geometryObj.GraphicsStyleId) as GraphicsStyle;
layername:
gStyle.GraphicsStyleCategory.Name
Thanks for the reply.
I too found the layer name the same way as you mentioned but still I will accept your answer as a solution.
Thanks & Regards
Sanjay Pandey
jeremytammik
Thanks to Fair59 for the nice succinct answer. Promoted to a blog post:
http://thebuildingcoder.typepad.com/blog/2017/02/revitserverapilib-truss-members-and-layers.html#5
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
zrodgersTSSSU
@Anonymous I am attempting to do the same thing but gstyle returns null. Any ideas?
Element elem = uidoc.Document.GetElement(elemId);
                    Options opts = app.Create.NewGeometryOptions();
                    GeometryElement geoElem = elem.get_Geometry(opts);
                    foreach(GeometryObject geoObj in geoElem)
                        GraphicsStyle gStyle = doc.GetElement(geoObj.GraphicsStyleId) as GraphicsStyle;
                        if(gStyle.GraphicsStyleCategory.Name == cadLayer)
                            GeometryInstance instance = geoObj as GeometryInstance;
                            if (null != instance)
                                foreach (GeometryObject instObj in instance.SymbolGeometry)
                                    if (instObj is Curve)
                                        ++curveCounter;
                                    else if (instObj is PolyLine)
                                        ++polylineCounter;
