FootPrintRoof or FaceWall? Which is the way to go?
I am writing an addin that adds stucco walls and ceilings (created as simple FootPrintRoofs to a Revit model, and it works ok, but on the topfloor things are becoming complex for the stucco roofs/ceiling (walls I can handle). This view shows the geometry I am having to dealing with. The next view shows the same, but now with DirectShapes, created from the room faces (obtained from the room solid). I want to create a dialogue that selects the faces and where the user can decide if there needs to be stucco added to the project. I have seen that roof by face is not supported yet by the API but maybe I can create a FootPrintRoof from the face geometry (which I have in memory). The other option is to create a FaceWall, however, that seems a lot of work because it needs to be created from a Mass. I found https://jeremytammik.github.io/tbc/a/1217_sloped_wall.htm#2
Which is the way to go? Is there anybody that can tell me if it is easy enough to create a FootPrintRoof from face geometry? Your help is much appreciated.
