Fire Alarms and MEP
Fire Alarms and MEP
Fire Alarms and MEP
In revit mep 2015 is there anyway I can give a device an imported property? For example..I have a load sheet in Excel for all my voltage drops batt calcs etc and I would like to be able to tell a horn strobe device if set to 15 cd specify my current draw that it saves into a table and then finally be able to build a device count what would be better is if I can build an entire library for the manufacture I use with part numbers etc. I am trying to automate the process the best I can. Any help is greatly appreciated.
jeremytammik
Dear Firealarmdesigner,
Please look at the FireRating SDK sample.
It is also included in the Revit API Xtra training labs:
http://thebuildingcoder.typepad.com/blog/2012/09/exporting-parameter-data-to-excel.html
http://thebuildingcoder.typepad.com/blog/2013/07/sydney-revit-api-training-and-vacation.html#4
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Will this work with autocad mep 2015?
jeremytammik
No.
Revit and Its API is Different:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.41
Jeremy Tammik
The Building Coder
dans557JT
Did you ever end up figuring this out?
