Finding nearest level
Hello everybody!
I am trying to find the nearest lower (and upper) level from a point.
I have been able to fint the nearest element (eg. a floor) using the next code:
ReferenceIntersector refIntersector = new ReferenceIntersector(view3D);
ReferenceWithContext referenceWithContext = refIntersector.FindNearest(elemPoint, new XYZ(0,0,-1));
Reference reference = referenceWithContext.GetReference();
XYZ lowerLevel = reference.GlobalPoint;
It finds the nearest element, but, unortunately, id does not find the nearest level.
I have tried using also it:
ElementClassFilter filter = new ElementClassFilter(typeof(Level));
ReferenceIntersector refIntersector = new ReferenceIntersector(filter, FindReferenceTarget.All,view3D);
but it does not work....
Any idea??
Thanks in advance!
Chema
Dear Chema,
Try this one.
      private Level getNearestBelowLevel(double _Zvaue)
            return new FilteredElementCollector(doc).OfClass(typeof(Level)).Cast<Level>().Where(x => x.Elevation < _Zvaue).OrderByDescending(x => x.Elevation).FirstOrDefault();
        private Level getNearestUpperLevel(double _Zvaue)
            return new FilteredElementCollector(doc).OfClass(typeof(Level)).Cast<Level>().Where(x => x.Elevation > _Zvaue).OrderBy(x => x.Elevation).FirstOrDefault();
Note: In case of Shared co-ordinate Some time also use x.ProjectElevation instead of x.Elevation.
Totally effective and much simpler!!!
Thanks So much!!!
Chema
joshua.lumley
Thank you...so simple it is miraculous.
yoniblum
Is there an equivalent function to do this in python, where the input is the z-coordinate and the output is the nearest above level?
