Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Finding coordinates relative to survey base point and project base point
8 REPLIES 8
Message 1 of 9
senne.vande.sompele
4940 Views, 8 Replies
Hi everybody,
I've been searching alot about this subject (and read alot) but can't find a solution.
I'm trying to find the coordinates for a point relative to the project base point.
I've found how to get them relative to the survey point as following:
ProjectLocation pl = doc.ActiveProjectLocation;
Transform ttr = pl.GetTotalTransform().Inverse;
 ProjectPosition projPosition = doc.ActiveProjectLocation.get_ProjectPosition(new XYZ(0, 0, 0));
LocationPoint loc = element.Location as LocationPoint;
if (loc != null)
    XYZ point = ttr.OfPoint(loc.Point);
this works perfectly even if I change the "The angle to the true north" but I can't find a way to get the position relative to the project base point.
Has someone have a solution for this?
greets
Senne
8 REPLIES 8
Message 2 of 9
define function  f(pt) = coordinate relative to surveypoint.
then  point-coordinate relative to project base point = f(pt) - f( project base point)
where
XYZ location of the project base point .X  = project_base_point.get_Parameter(BuiltInParameter.BASEPOINT_EASTWEST_PARAM).AsDouble());
XYZ location of the project base point .Y  = project_base_point.get_Parameter(BuiltInParameter.BASEPOINT_NORTHSOUTH_PARAM).AsDouble());
XYZ location of the project base point .Z  = project_base_point.get_Parameter(BuiltInParameter.BASEPOINT_ELEVATION_PARAM).AsDouble());
Message 3 of 9
This is correct as long as your angle to the true north is 0°.
After you change this angle the coordinates you get back are not the same as the spot coordinates I have set
Message 4 of 9
It should be accurate, even with a rotated true north.
Message 5 of 9
Currently i'm doing the following
var basePoints = doc.NewFilteredElementCollector().OfClass<BasePoint>();
var projectPoint = basePoints.First(x => !x.IsShared);
var surveyPoint = basePoints.First(x => x.IsShared);
var px = projectPoint.get_Parameter(BuiltInParameter.BASEPOINT_EASTWEST_PARAM).AsDouble();
var py = projectPoint.get_Parameter(BuiltInParameter.BASEPOINT_NORTHSOUTH_PARAM).AsDouble();
var pz = projectPoint.get_Parameter(BuiltInParameter.BASEPOINT_ELEVATION_PARAM).AsDouble();
XYZ project = new XYZ(px, py, pz);
var sx = surveyPoint.get_Parameter(BuiltInParameter.BASEPOINT_EASTWEST_PARAM).AsDouble(); var sy = surveyPoint.get_Parameter(BuiltInParameter.BASEPOINT_NORTHSOUTH_PARAM).AsDouble(); var sz = surveyPoint.get_Parameter(BuiltInParameter.BASEPOINT_ELEVATION_PARAM).AsDouble(); XYZ survey = new XYZ(sx, sy, sz); var projectLocation = doc.ActiveProjectLocation; var surveyPosition = projectLocation.get_ProjectPosition(survey); survey = new XYZ(-surveyPosition.EastWest, -surveyPosition.NorthSouth, -surveyPosition.Elevation);
if (loc != null)
XYZ projectPoint = ttr.OfPoint(project);
var x = Math2.FeetToMeters(point.Y - projectPoint.X);
var y = Math2.FeetToMeters(point.Y - projectPoint.Y);
var z = Math2.FeetToMeters(point.Z - projectPoint.Z)
But this gives me incorrect values for x,y,z
Do you see what i'm doing wrong
Message 6 of 9
I did some testing, and discovered that the spotcoordinate with origin Project Base doesn't change if the angle to True North changes.
So it's simpler than I thought. The coordinate relative to project base point is in project coordinates. (no Transform required).
XYZ  coord_to_proj_base  =  loc.Point.Subtract( project )
Message 7 of 9
hi I tried that but I think I'm doing something wrong here's the code i'm using:
 XYZ projectPoint = loc.Point.Subtract(project);
Message 8 of 9
a new way to determine the coordinates of the project base point:
                XYZ project = projectPoint.get_BoundingBox().Min;
Message 9 of 9
Thank you very much that was the solution!
Rail Community
