Find user-defined view filters that affect certain elements
tebogo.schultzH5FH3
tebogo.schultzH5FH3
Back with another fun one.  I need to seek out filters defined on a view (or template) that may affect the visibility of important elements that are being added to a sheet by my add-in.
Can anyone help me fill in the missing method?
        static void checkAndRemoveFilters(Document doc, View view, ElementId mustBeVisible)
            if(view.GetFilters().Count() > 0)
                foreach(ElementId id in view.GetFilters())
                    FilterElement filter = doc.GetElement(id) as FilterElement;
                    //if(filter.wouldHide(mustBeVisible))
jeremytammik
It might help if you describe some examples of tricky criteria that might cause an important element to be invisible.
Jeremy Tammik
Developer Technical Services
The Building Coder
tebogo.schultzH5FH3
That's what I don't know?  But for now, I'm talking about just the filters.
mhannonQ65N2
You're going to have to switch on/check the type of the FilterElement to determine how to check this.
For ParameterFilterElements, you'll need to call GetElementFilter to get an ElementFilter, then call PassesFilter on the ElementFilter with the element(s) of interest.
For SelectionFilterElements, you can call Contains with the Id(s) of the element(s) of interest.
Personally, I would put the code for determining if a FilterElement affects a given Element in an extension method or local function.
