Find projected 3D lines intersect like Trim/Extend command
andre_adc-dao
andre_adc-dao
I'm trying to create Trim/Extend command using Revit API to connect pipes or ducts. I didn't find any method to do that. I think I have to find myself the projected intersection point but I don't know how to do that. The Intersect method seems to return only real intersection (not projected).
Is anybody have an idea how to do that?
André
jeremytammik
Dear André,
Thank you for your query.
Under optimal conditions, there is no need for you to create any such command, because the pipes and ducts will calculate their intersection point on their own when you ask Revit to connect them.
Please read the series of posts on The Building Coder on implementing the rolling offset to see various way of making use iof this functiontionality:
http://thebuildingcoder.typepad.com/blog/2014/01/final-rolling-offset-using-pipecreate.html
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
