FilteredElementCollector -> get all instances except of category X
jnoordzij
jnoordzij
I am filtering for FamilInstances in a doc using FilteredElementCollector.
I want to get all family instances, except the titleblocks.
public ICollection<Element> CollectFamilyInstances(Document doc)
            FilteredElementCollector collector
                = new FilteredElementCollector(doc);
            ICollection<Element> collection
              = collector.OfClass(typeof(FamilyInstance))
                .ToElements();
            return collection;
How can i apply a filter over this collection so that instances of category OST_TitleBlocks are omitted from this collection?
jnoordzij
I do this now but there has to be a cleaner way...
                .ToElements();
            ICollection<Element> collection2 = new List<Element>();
            foreach (Element e in collection)
                if (!e.Category.Equals(BuiltInCategory.OST_TitleBlocks))
                    collection2.Add(e);
            return collection2;
thanks for any extra advice on this!
jnoordzij
Got it to work!
            ElementCategoryFilter fi = new ElementCategoryFilter(BuiltInCategory.OST_TitleBlocks, true);
              = collector.OfClass(typeof(FamilyInstance)).WherePasses(fi)
                .ToElements();
            return collection;
Not tested, but maybe using quick filter is what you are looking for (if you want just titleblocks category):
ElementCategoryFilter titleblockfilter = new ElementCategoryFilter(BuiltInCategory.OST_TitleBlocks);
                .WherePasses(titleblockfilter)
                .ToElements();
naveen.kumar.t
Autodesk Support
Autodesk Support
HI @jnoordzij
ExclusionFilter Class helps you to filter elements by excluding particular elements.
Exclusion Filter Class
FilteredElementCollector Collector = new FilteredElementCollector(doc).OfClass(typeof(FamilyInstance)).WhereElementIsNotElementType();
IList<ElementId> eids = Collector.ToElementIds() as IList<ElementId>;
ICollection<ElementId> exclude_elements = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_TitleBlocks).WhereElementIsNotElementType().ToElementIds() as ICollection<ElementId>; ExclusionFilter EF = new ExclusionFilter(exclude_elements); IList<ElementId> elementsAfterExclusion = Collector.WherePasses(EF).OfClass(typeof(FamilyInstance)).ToElementIds() as IList<ElementId>;
If this helped solve your problem please mark it as solution, so other users can get this solutions as wellSmiley Happy
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jnoordzij
In conclusion of this thread:
I haven't checked the solution provided by @naveen.kumar.t , since I found a working solution beforehand, but that solution might also work.
My own solution was that the ElementCategoryFilter has an additional boolean option that provides the option to match all elements which are NOT of the given category. So an "invert" boolean. Hence the (invert=) "true" at the end of
