FilteredElementCollector:Filter the models displayed in the active view in the RevitLinkInstance
SimonaQQ
SimonaQQ
Hi All,
I'm trying to filter models in the active view
var wallList = new FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(typeof(Wall)).ToList();
It works well in the local document.However, when the model is in revitlinkinstance, it does not work
new FilteredElementCollector(linkDoc, doc.ActiveView.Id).OfClass(typeof(Wall)).ToList();
This throws an exception.
So, how do I filter the models in the active view in revitlinkinstance?
Thank you!
caroline.gitonga
Hi @SimonaQQ ,
The first step to accessing linked data in Revit API is to get all the active documents loaded in the current Revit session. This will use Application.Documents().The returned collection will include both local and linked documents. We can then filter the collection to obtain the Linked documents only. By iterating through the Revit Linked documents collection , comparing the name of the Linked File with that of the document object you can get the actual document you wish to work with. Once you get the right document, you can be able to get the elements using your line of code you have provided.
Kindly refer to these resources for more detailed explanation.
Carol Gitonga, Developer Advocacy and Support, ADN Open
SimonaQQ
First of all, thank you very much.
Maybe you didn't understand me because of my poor English.
What I want is to filter the model displayed in the current active view, and the model is in revitlinkinstance.
So I use the new filteredelementcollector (DOC, Doc. Activeview. ID), an overloaded method with view ID.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @SimonaQQ ,
Please take a look at this below link
https://forums.autodesk.com/t5/revit-api-forum/collect-elements-from-link-document-in-view-of-host-d...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
