Filter View Schedule by shared parameter & shared parameter
Nathan.HilsonN67V6
Nathan.HilsonN67V6
Just started digging into the api for schedules & trying to manipulate the Schedule creation to filter through parameters & shared parameters instead of builtinparameters. I'm guessing a element collector will be the route to go? Here is the code that I am using.
ScheduleCreationUtility:
// (C) Copyright 2003-2019 by Autodesk, Inc. All rights reserved.
// Permission to use, copy, modify, and distribute this software in
// object code form for any purpose and without fee is hereby granted
// provided that the above copyright notice appears in all copies and
// that both that copyright notice and the limited warranty and
// restricted rights notice below appear in all supporting
// documentation.
// AUTODESK PROVIDES THIS PROGRAM 'AS IS' AND WITH ALL ITS FAULTS.
// AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
// MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
// DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
// UNINTERRUPTED OR ERROR FREE.
// Use, duplication, or disclosure by the U.S. Government is subject to
// restrictions set forth in FAR 52.227-19 (Commercial Computer
// Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
// (Rights in Technical Data and Computer Software), as applicable.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Security.Cryptography.X509Certificates;
using System.Text;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Microsoft.Office.Interop.Excel;
namespace ScheduleCreationUT
    /// <summary>
    /// Utility class that contains methods of view schedule creation and schedule sheet instance creation.
    /// </summary>
    class ScheduleCreationUtility
        private static BuiltInParameter[] s_skipParameters = new BuiltInParameter[] { BuiltInParameter.ALL_MODEL_MARK };
        /// <summary>
        /// Create view schedule(s) and add them to sheet.
        /// </summary>
        /// <param name="uiDocument">UIdocument of revit file.</param>
        public void CreateAndAddSchedules(UIDocument uiDocument)
            TransactionGroup tGroup = new TransactionGroup(uiDocument.Document, "Create schedules and sheets");
            tGroup.Start();
            ICollection<ViewSchedule> schedules = CreateSchedules(uiDocument);
            foreach (ViewSchedule schedule in schedules)
                AddScheduleToNewSheet(uiDocument.Document, schedule);
            tGroup.Assimilate();
        /// <summary>
        /// Create a sheet to show the schedule.
        /// </summary>
        /// <param name="document">DBDocument of revit file.</param>
        /// <param name="schedule">View schedule which will be shown on sheet.</param>
        private void AddScheduleToNewSheet(Document document, ViewSchedule schedule)
            //Create a filter to get all the title block types.
            FilteredElementCollector collector = new FilteredElementCollector(document);
            collector.OfCategory(BuiltInCategory.OST_TitleBlocks);
            collector.WhereElementIsElementType();
            Transaction t = new Transaction(document, "Create and populate sheet");
            t.Start();
            //Get ElementId of first title block type.
            ElementId titleBlockId = collector.FirstElementId();
            //Create sheet by gotten title block type.
            ViewSheet newSheet = ViewSheet.Create(document, titleBlockId);
            newSheet.Name = "Sheet for " + schedule.Name;
            document.Regenerate();
            //Declare a XYZ to be used as the upperLeft point of schedule sheet instance to be created.
            XYZ upperLeft = new XYZ();
            //If there is an existing title block.
            if (titleBlockId != ElementId.InvalidElementId)
                //Find titleblock of the newly created sheet.
                collector.OwnedByView(newSheet.Id);
                Element titleBlock = collector.FirstElement();
                //Get bounding box of the title block.
                BoundingBoxXYZ bbox = titleBlock.get_BoundingBox(newSheet);
                //Get upperLeft point of the bounding box.
                upperLeft = new XYZ(bbox.Min.X, bbox.Max.Y, bbox.Min.Z);
                //Move the point to the postion that is 2 inches right and 2 inches down from the original upperLeft point.
                upperLeft = upperLeft + new XYZ(2.0 / 12.0, -2.0 / 12.0, 0);
            //Create a new schedule sheet instance that makes the sheet to show the data of wall view schedule at upperLeft point.
            ScheduleSheetInstance placedInstance = ScheduleSheetInstance.Create(document, newSheet.Id, schedule.Id, upperLeft);
            t.Commit();
        public string GetParamValueByGuid(Guid guid, Element e)
            var paramValue = string.Empty;
            foreach (Autodesk.Revit.DB.Parameter parameter in e.Parameters)
                if (parameter.IsShared)
                    if (parameter.GUID == guid)
                        paramValue = parameter.AsString();
            return paramValue;
        /// <summary>
        /// Create a view schedule of wall category and add schedule field, filter and sorting/grouping field to it.
        /// </summary>
        /// <returns>ICollection of created view schedule(s).</returns>
        private ICollection<ViewSchedule> CreateSchedules(UIDocument uiDocument)
            Document document = uiDocument.Document;
            Transaction t = new Transaction(document, "Create Schedules");
            t.Start();
            List<ViewSchedule> schedules = new List<ViewSchedule>();
            //Create an empty view schedule of Fabrication Pipe category.
            ViewSchedule schedule = ViewSchedule.CreateSchedule(document, new ElementId(BuiltInCategory.OST_FabricationPipework), ElementId.InvalidElementId);
            schedule.Name = "BOM";
            schedules.Add(schedule);
            //Iterate all the schedulable field gotten from the Fabrication Pipe view schedule.
            foreach (SchedulableField schedulableField in schedule.Definition.GetSchedulableFields())
                //Judge if the FieldType is ScheduleFieldType.Instance.
                if (schedulableField.FieldType == ScheduleFieldType.Instance)
                    //Get ParameterId of SchedulableField.
                    ElementId parameterId = schedulableField.ParameterId;
                    //If the ParameterId is id of BuiltInParameter.ALL_MODEL_MARK then ignore next operation.
                    if (ShouldSkip(parameterId))
                        continue;
                    //Add a new schedule field to the view schedule by using the SchedulableField as argument of AddField method of Autodesk.Revit.DB.ScheduleDefinition class.
                    ScheduleField field = schedule.Definition.AddField(schedulableField);
                    //Judge if the parameterId is a BuiltInParameter.
                    if (Enum.IsDefined(typeof(BuiltInParameter), parameterId.IntegerValue))
                        BuiltInParameter bip = (BuiltInParameter)parameterId.IntegerValue;
                        //Get the StorageType of BuiltInParameter.
                        StorageType st = document.get_TypeOfStorage(bip);
                        //if StorageType is String or ElementId, set GridColumnWidth of schedule field to three times of current GridColumnWidth.
                        //And set HorizontalAlignment property to left.
                        if (st == StorageType.String || st == StorageType.ElementId)
                            field.GridColumnWidth = 3 * field.GridColumnWidth;
                            field.HorizontalAlignment = ScheduleHorizontalAlignment.Left;
                        //For other StorageTypes, set HorizontalAlignment property to center.
                        else
                            field.HorizontalAlignment = ScheduleHorizontalAlignment.Center;
                    //Filter the view schedule by volume
                    if (field.ParameterId == new ElementId(BuiltInParameter.HOST_VOLUME_COMPUTED))
                        double volumeFilterInCubicFt = 0.8 * Math.Pow(3.2808399, 3.0);
                        ScheduleFilter filter = new ScheduleFilter(field.FieldId, ScheduleFilterType.GreaterThan, volumeFilterInCubicFt);
                        schedule.Definition.AddFilter(filter);
                    //Filter the view schedule by Product Long Description Joint
                    if (field.ParameterId == new ElementId(BuiltInParameter.FABRICATION_PRODUCT_DATA_LONG_DESCRIPTION))
                        string JointFilterFabPipe = "Joint" ;
                        ScheduleFilter filter = new ScheduleFilter(field.FieldId, ScheduleFilterType.NotContains, JointFilterFabPipe);
                    //Filter the view schedule by Product Long Description Joints
                        string JointFilterFabPipe = "Joints";
                    //Filter the view schedule by Vic_Sequence
                    //Group and sort the view schedule by WORKSET
                    if (field.ParameterId == new ElementId(BuiltInParameter.ELEM_PARTITION_PARAM))
                        ScheduleSortGroupField sortGroupField = new ScheduleSortGroupField(field.FieldId);
                        sortGroupField.ShowHeader = true;
                        schedule.Definition.AddSortGroupField(sortGroupField);
                    //Group and sort the view schedule by Product Long Description
                        sortGroupField.ShowHeader = false;
                    //Group and sort the view schedule by Product Size Description
                    if (field.ParameterId == new ElementId(BuiltInParameter.FABRICATION_PRODUCT_DATA_SIZE_DESCRIPTION))
            t.Commit();
            uiDocument.ActiveView = schedule;
            return schedules;
        /// <summary>
        /// Judge if the parameterId should be skipped.
        /// </summary>
        /// <param name="parameterId">ParameterId to be judged.</param>
        /// <returns>Return true if parameterId should be skipped.</returns>
        private bool ShouldSkip(ElementId parameterId)
            foreach (BuiltInParameter bip in s_skipParameters)
                if (new ElementId(bip) == parameterId)
                    return true;
            return false;
ScheduleCreationCommand:
// object code form for any purpose and without fee is hereby granted,
// documentation.
// AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
using System;
using System.Windows.Forms;
using System.Collections;
using Autodesk.Revit;
using ScheduleCreationUT;
namespace ScheduleCreationC
    /// <summary>
    /// Implements the Revit add-in interface IExternalCommand
    /// </summary>
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
    public class ScheduleCreationCommand : IExternalCommand
        /// <summary>
        /// Implement this method as an external command for Revit.
        /// </summary>
        /// <param name="commandData">An object that is passed to the external application
        /// which contains data related to the command,
        /// such as the application object and active view.</param>
        /// <param name="message">A message that can be set by the external application
        /// which will be displayed if a failure or cancellation is returned by
        /// the external command.</param>
        /// <param name="elements">A set of elements to which the external application
        /// can add elements that are to be highlighted in case of failure or cancellation.</param>
        /// <returns>Return the status of the external command.
        /// A result of Succeeded means that the API external method functioned as expected.
        /// Cancelled can be used to signify that the user cancelled the external operation
        /// at some point. Failure should be returned if the application is unable to proceed with
        /// the operation.</returns>
        public virtual Result Execute(ExternalCommandData commandData
            , ref string message, ElementSet elements)
            try
                UIDocument uiDocument = commandData.Application.ActiveUIDocument;
                ScheduleCreationUtility utility = new ScheduleCreationUtility();
                utility.CreateAndAddSchedules(uiDocument);
                return Result.Succeeded;
            catch (Exception ex)
                message = ex.Message;
                return Result.Failed;
Any help/guidance would be greatly appreciated.
RPTHOMAS108
There is far too much code to understand specifically what you are interested in I can only guess from your description that you want the SharedParameter version of this:
You could filter for ParameterElements/SharedParameterElements in the usual way and match against:
SharedParameterElement.GuidValue (for shared parameters)
ParameterElement.Name (for non-shared project parameters)
Those matching items then have an Id property because they are derived from elements.
Nathan.HilsonN67V6
I'm having a tough time with these schedules. I'm Closer to what I'm looking for though. This is what I have.
                    //Filter the view schedule by Vic_FieldMaterial
                    //Filter the view schedule by Joint
                        string Joint = "Joint";
                        ScheduleFilter filter = new ScheduleFilter(field.FieldId, ScheduleFilterType.Contains, Joint);
                        schedule.Definition.AddFilter(new ScheduleFilter(field.FieldId, ScheduleFilterType.Equal,
                            ("Vic_Sequence")));
                            ("Vic_FieldMaterial")));
                        string Joints = "Joints";
                        ScheduleFilter filter = new ScheduleFilter(field.FieldId, ScheduleFilterType.Contains, Joints);
                    //Group and sort the view schedule by type
                    if (field.ParameterId == new ElementId(BuiltInParameter.ELEM_TYPE_PARAM))
This is what I want:
RPTHOMAS108
For existing schedule, you can compare ScheduleField.ParameterId via
ScheduleDefinition.GetFieldOrder & ScheduleDefinition.GetField(ScheduleFieldId) to get the fields to add filters i.e. no need to iterate other than via Linq.
 public Result Obj_221203a(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message,
        Autodesk.Revit.DB.ElementSet elements)
            UIApplication UIApp = commandData.Application;
            UIDocument UIDoc = commandData.Application.ActiveUIDocument;
            if (UIDoc == null)
                return Result.Cancelled;
            Document IntDoc = UIDoc.Document;
            ElementId LongDescParamId = new ElementId(BuiltInParameter.FABRICATION_PRODUCT_DATA_LONG_DESCRIPTION);
            FilteredElementCollector FEC = new FilteredElementCollector(IntDoc);
            ParameterElement PE0 = FEC.OfClass(typeof(ParameterElement))
                        .OfType<ParameterElement>().Where(k => k.Name == "Supplier").FirstOrDefault();
            ParameterElement PE1 = FEC.OfClass(typeof(ParameterElement))
                        .OfType<ParameterElement>().Where(k => k.Name == "Vic_Sequence").FirstOrDefault();
            //if Supplier etc.is SP then filter for SharedParameterElement with GuidValue
            ElementId SupplierParamId = PE0.Id;
            ElementId VicSequenceParamId = PE1.Id;
            using (Transaction tx = new Transaction(IntDoc, "Create schedule"))
                if (tx.Start() == TransactionStatus.Started)
                    ViewSchedule VS = ViewSchedule.CreateSchedule(IntDoc,
                    VS.Name = "BOM";
                    IList<SchedulableField> SFields = VS.Definition.GetSchedulableFields();
                    SchedulableField ScLongDesc = SFields.FirstOrDefault(k => k.ParameterId == LongDescParamId);
                    SchedulableField ScSupplier = SFields.FirstOrDefault(k => k.ParameterId == SupplierParamId);
                    SchedulableField ScVicSequence = SFields.FirstOrDefault(k => k.ParameterId == VicSequenceParamId);
                    ScheduleField SF0 = VS.Definition.AddField(ScSupplier);
                    ScheduleField SF1 = VS.Definition.AddField(ScVicSequence);
                    ScheduleField SF2 = VS.Definition.AddField(ScLongDesc);
                    VS.Definition.AddFilter(new ScheduleFilter(SF0.FieldId, ScheduleFilterType.HasValue));
                    VS.Definition.AddFilter(new ScheduleFilter(SF1.FieldId, ScheduleFilterType.Contains, ""));
                    VS.Definition.AddFilter(new ScheduleFilter(SF2.FieldId, ScheduleFilterType.NotContains, "Joint"));
                    VS.Definition.AddFilter(new ScheduleFilter(SF2.FieldId, ScheduleFilterType.NotContains, "Joints"));
                    tx.Commit();
