filter or analyze selection
matt.johnson1253
matt.johnson1253
Hello all, I have a rather basic question.
I am creating a plugin where the user is prompted to select an element.  I want them to select a Model Line.
1. Is there a way to filter the selection.PickObject() function so that only model lines are selectable?
2. How can I find out if a given element is a Model Line or not?  I can't tell from the API docs if that's a Category, Family, Type or something else.
Thanks for any insights.
Mohamed_Arshad
HI @matt.johnson1253
   You can use ISelectionFilter Interface this will helps you select only Defined Element in your Model Line. Kindly Check the Below code Implementation.
Reference Code:
public Result Execute(ExternalCommandData commandData, ref string msg, ElementSet elements)
            UIApplication uiApp = commandData.Application;
            Application app = uiApp.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Document doc = uiDoc.Document;
           Reference refer= uiDoc.Selection.PickObject(ObjectType.Element, new SelectionFilter());
            if(refer !=null)
                ModelCurve curve = doc.GetElement(refer) as ModelCurve;
    public class SelectionFilter : ISelectionFilter
        public bool AllowElement(Element elem)
            bool result = false;
           if(elem is ModelCurve)
                result = true;
            return result;
        public bool AllowReference(Reference reference, XYZ position)
            return true;
Additional Links:
https://spiderinnet.typepad.com/blog/2011/04/implement-the-iselectionfilter-interface-of-revit-api.h...
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
